Coolant flush done. Thanks!
Los Angeles
Thanks to e9999 for the write up.
Did it last weekend and it went very well. Didnt use the Prestone T, but picked up a bunch of stuff from the hardware store though.
I think the coolant in there was original red and had been topped off at some point with after market green stuff. During the flushing(heater, block, radiator) nothing really came out that looked grey or sludgy, so thats good. Looking into the radiator I could see some green gunk in there, but it wouldnt really come out unless I stuck my finger down in there then some cloudy green stuff would get dislodged and flush out....a little worried, but I'm not going to pull the radiator yet.
Filled with distilled water, ran truck up to temp, turned on all the heaters and let idle for a few minutes. Let truck cool down and drained again. Filled with distilled and toyota red. Only 3 total gallons went in on the distilled flush and final fill, so I think 3/4 gallon gets left in there each flush. I worked it out, and with one distilled flush after the garden hose flushing and a final fill there is approx ~4% normal water in there right now. I ran out of daylight or I would have flushed one more time with distilled.
Here's some pics...(by the way, anyone know how to get pics to automatically resize???? having to do it manually kills me)
See if this works for the pics
http://www.flickr.com/photos/21860717@N07/sets/72157603461664957 (you have to start at the bottom for the chronological effect)
Did you feel any efect in the overall engine temp . ?
No, not noticeable. The needle pretty much is in the exact same place it was when I first got the truck. In fact, it may have climbed a half-needle
I never done a real flush .. only get out all my old cooland from my rad ( engine off ) and fill with new .. of course I now there are much old fluid still inside ..
bpenn; where did you get the brass Y and the hose adaptors? By flushing backwards into the top radiator hose, would the water get by the thermostat?
Hardware store for the brass attachments and hose from auto parts store.
I dont think the water would flow that way...could be wrong though. That hose from the thermostat to the radiator was the one spot I think I missed.
