Sure it's possible just get the parts off a 90-93 hdj81 easy. I'm planing to do the same in the rear but keep the bigger front breaks.
Keep your 16" brake on your front axle. I did it the other way. 1992 15" Hdj converted to 16" brakes at front. 15" rims of the 70 series, means original design, but wider offset (30mm per wheel, that is in your currency 1" and a slice of toast). I had to grind the caliper, but just to lose some imperfactions.
The 16" brake is so much better, you would not believe it, even it is working with the same piston size. Tire is 33 x 10.5 BFG.
