Converting 3FE to 2WD?
Arizona
Has anyone converted their 3FE to 2WD. I live in the dessert and don't ever drive in snow unless I want to. I am wondering if converting to part time 4WD coud be a solution to my poor MPG. Anyone have any info?
Solution to poor MPG? Not likely- the numbers I've seen tossed around on this board have mostly been under 1 mpg improvement.
this has been discussed many times on the forum...
Fiveo- is that a smokey and the bandit quote youre quoting? If so - its incorrect.
BINGO!!!! Sheriff Buffard T Justice himself, "Jr There aint no way. no way, you came form my loins!"
I would adjust your quote then. Technically - thats not what Sheriff Justice says in the movie.;)
Whatever you're getting, I'm getting worse.
8 MPG. :eek:
take off your 33" tires, that'll give better mpg...
I quit caring what my mpg were after I went to 35's.
If you do decide to convert to part-time, please post up your results, we need more real-world opinions about it.
177MPH Educate me then. What is the line exactly?
Not a biggie - but I figured - if youre gonna quote it...
The line is "what were dealing with here is a complete lack of respect for the law"
You were close!:)
I guess your right. Best movie ever made!!! Ill edit it.
if you're going to correct quotes.... you might consider adding an apostrophe
