Convert from fusible link to fuse or circuit breaker - discussion
@CruiserTrash has a good turnkey solution. I did mine and took some work but done now. I had the Blue Sea box using Bussman type 1 breakers but took up too much room for too little capacity of a box. I needed 1 stop all systems. The Egis hub core distribution bar is rated to 500 amps. Notice the post are at each corner. Their other system allow add on or daisy chain other supply nice and neat. Another option I tried before settling on the Egis was PAL fuses. You can get some smaller inline setups. The blade connectors are .375(?) not .250 and the same as a relay male connector. Fab up a small harness to plug in a PAL and tie off. This would look similar to fuselink but modern.
