CONVERSION - Early Dashboard to Late Dashboard
For some reason I´ve always loved the late dashboard version and plan to someday do the switch.
I was wondering if someone has done it already or knows of anyone that has?
If so, how complicated was it? :hhmm:
I have thought about the same thing but backed off. I would assume the center air ducts would be about the same with minor modification, the one issue I could see is the A/C unit if it isn't the same pinout but otherwise everything should fit.
If you decide to do it I will look forward to reading about it.
Yeah, go buy yourself a later model Cruiser and swap over your pine tree air freshener. :D
I have both and barely notice the difference. Sounds like a lot of work for little return.
I kinda prefer the early dashbord....does seem like a lot of work...I would probably be looking for another cruiser if I felt that way. I will be interested to read about it when you do it!!!!!
I like my 93-94 dash, I just wish it didn't have so many little cracks, when is somebody going to make a stainless steel, aluminum, rubber, gold or titanium replacement, anything but plastic.:lol:
Same here mine has some pretty big cracks in it, I am thinking of sanding it down and using body filler to smooth it out and paint it.
In theory it should fit, but the clusters might not be compatable. Seems like a ton of work and very little return. Do you want the airbags to be functional? That will makes things more complicated.
I´ll keep you all posted if the project goes :)
Guessing he doesn't live in america and that image above shows the later dash without airbags.
I think that all the gauges are the same size, so in theory the older gauge cluster should fit in the newer dash.
Yeah, the PS-side grabhandle is another giveaway...
UNLESS Mot has hooked you up with one of those grabhandles:)
Sounds like an enormous bunch of work to swap in a newer dash. Some of the issues have already been mentioned, but I'd bet there are others that would be lurking in the harness. Nothing that couldn't be solved with enough money and time, but with the price of used 80s, it'd be easier just to buy a newer dash with a FZJ80 attached to it.
My first clue was the HDJ80 in the signiture...LOL! I love the newer style interior. Some people really hate it. I guess it is a matter of preference. Blondes or Brunettes, old or new style dash...LOL.
The ony reason to swap for the new style dash it's the easy access to the stereo and AC stuff .. that it's a big pita in the early dash style ..
I've never been a fan of the early style. Looks dated and like it should be in a supra.
Do it!
I hate working behind/beneath/around the dash - can't even imagine how much of a PITA that swap would be. Good luck!
I like both dashes but I would never swap them. I can't imagine the electrical gremlins lurking in their. Sell the truck and buy one with the dash you want.
