IMHO the angle iron just looks like an ADHOC, quick fix. My thoughts would be to make a jig so the OEM control arm length can be maintained, cut the control arm in half, sleeve it with tubing that has the same ID as the control arms OD of your desired wall thickness, drill multiple holes along the sleeve, weld it at each end around the stock control arm and plug weld all the holes. Have not done this myself, but is the route I would/will take.
Agreed. However if an ADHOC quick fix adequately provides a solution to the problem, than no need for the extra work. But having ran leafs on all previous rigs, I dont have any experience with control arm armoring techniques.
However this is second to my primary concern of what to do with the LCA brackets or mounts. (see about 4 posts up)
Gorilla glue would be my second choice.
