Control Arm Drop Brackets???
Because if you use your 80 off road they are terrible. Hang up everywhere. Expecially in reverse. Why even bother with them when you can use castor plates?? Poor choice if you do
I disagree. I ran the rubicon, moab, and all over the Socal moutains with drop brackets on my old 80 and it wasn't an issue. Guys say you get hung up on them. Not true. You do land on them often and slam them often but I always just slid off of them. They also lower the pivot point of the control arms allowing for better articulation/increased flex compared to the washer mod or plates. They also recenter the axle into the wheel well correctly. They are visually a bit ugly just hanging there but work great and were never an issue offroad for me.
I disagree. I ran the rubicon, moab, and all over socal moutains with drop brackets on my old 80 and it wasn't an issue. Guys say you get hung up on them. Not true. You do land on them often and slam them often but I always just slid off of them. They also lower the pivot point of the control arms allowing for better articulation/increased flex compared to the washer mod or plates. They also recenter the axle into the wheel well correctly. They are visually a bit ugly just hanging there but work great and were never an issue offroad for me.
What sire tires?
When I bought my 80 it had 4" drop brackets, I agree with everything bhicks says above. I only had to adjust my front pinion angle by about 1/8" to get it perfect (washer mod) with no drive line vibrations (Toyota DC drive line)
I agree at least on the wheeling I've done so far as well. Also, I have a 97 with slider cat protection and the taller MAF drop brackets on 315s and they hang down lower then the cats giving an extra layer of protection on some obstacles.
Also, the alignment was never an issue and my rig with 340k travels at 80-90 with stock drives shafts and no vibrations.
Years ago both sides the MAF where mangled after a season of wheeling. I've also bent a few front lower control arms. I wheel quite conservative also. I Just wheel often.
Yeah, my drop brackets have some non-stock bends in them and both my control arms have some slight bends as well... The PO wheeled my rig with authority, I don't plan on it. My intended purpose for it is camping and exploring.. not rock crawling.
Yep. Mine were mangled too but they continued to work fine. I did add some plating and additional welds to reinforce the drop brackets just before I sold that 80. Not sure if it helped but it didn't hurt.
I've seen your vids... you're hardcore don't be all humble... you do some very difficult terrain. Don't make me link up some vids.
