Contact pattern Question?
Wild Idaho
Take a look at this pattern......Too close to the heel right??? If so, I need to add a thicker shim under the large pinion bearing race to move the pinion closer to the center of the gear..
Tell me if I'm wrong....Cheers!
Not wanting to slam anyone, (especially Charlie) but this pattern makes my diff howl really loud....Backlash is .009", preload is in spec. at 18 inch/lbs...Bearings are new. So, I guess the gearset is shot if this pattern is good to go....right?? BTW, it's a rear diff.
Cheers!
My limited experience is that used gear sets do not always give an ideal pattern, but they don't necessarily howl. If the gears have been run for a long time with bad bearings or a bad contact pattern it seems reasonable that they may wear in a manner that makes them impossible to correct. It isn't that hard to re-shim it, so you could try it and find out. Alternatively, used third members are cheap.
Run the pattern on the coast side and see how it turns out.
The coast side looks pretty bad to me....I'll attach a pic tonite for the group...Then I'll probably do like PinHead said, and just try re-shimming the pinion a bit thicker...
Here you go.......what do ya'll think now?
If it is a used gear set, I would not stress the pattern too much...You want it in the ballpark, but as it has been stated already, used gearsets do not always give you a good pattern, and if they were run for any lenght of time with bad bearings, you will have a hard time getting a good pattern, or have them run quiet. Set your backlash, check your pattern, and run it.
Are you 100 percent sure that the rear diff. is the issue? What is the condition of the rear axle wheel bearings and race or race area on the axle shaft? What is the condition of the slip and stub on the rear shaft, or the joints?
Just tossing other things out here...I know too many peope that have pointed fingers at the center section being the reason for noise, only to find out that it was something else...
Good luck!
-Steve
The contact is all the way out on the toe on the coast side. Contact patterns like this tend to howl. I would actually try a thinner shim to center the contact on the coast side. This will also move the contact up higher ont he tooth. If you can'e get it centered in both directions there is somehting wrong with the gear set.
My personal preference would be to just get another good used 3rd member, but I understand if you feel motivated to try fixing it too. I hate letting this kind of stuff defeat me after I have put a lot of effort in it. I tried every possible pinion position shim one time and I never did get an ideal looking contact pattern on a used gear set, but it didn't howl. As long as the contact idoesn't extend all the way at the end of the tooth, it seems to work OK.
-Steve
Actually, no...the rear wheel bearings I will look into..The slip and shaft are great as they are new from Six States DL shop....
It's all apart, so I will look into the wheel bearings 1st, then play with the shims a bit since it is out of the rig :)
I love the smell of gear oil in the morning......smells like.....victory! Or somethin' like that anyway
Cheers!
I will report back what I find for all to snicker at if necessary.............
The race area of the rear axle shaft should be a tattle tale of a questionable rear axle bearing...as would missing or damaged rollers... ;)
Good luck!
-Steve
So, I tried a slightly thicker pinion shim. About .005. Set pinion preload to about 12 inch/lbs, set ring gear backlash to .0075". The pix tell the story I hope...What do y'all think now?? I will install it this week and let you know how it sounds..... Rear axle bearings look fine to me BTW.
The drive side is 1st, coast 2nd.......
run it ;) ;)
I like it,
In a perfect world I would like the coast side a bit more centered but honestly, if you run a quality gear oil you sould be fine.
Dang, I hate it when I forget to post results.....Installed the last adjustments, and the unit is quiet and smooth! Many thanks to Pin_Head for his advice and excellent writeup! Could not have done it without the pics and excellent tutorial he provided! Been running it now for over 3 months and it's smoookin'!!
Thanks to all!
Cheers!
