Constant Power in the Hatch?
Is there a source of constant 12v in the hatch [Of an 1994 HDJ81]? I'd like to run a small LED bar in there.
No constant power in the hatch for '96. The hatch latch switch in negative switching power but disconnected it can be used to trigger your new LED set up. I used the rear window defogger power for exactly what you are wanting to do by jumping out the relay for constant always on power to the hatch.
Try the blue wire that goes to the hatch wiper. Should be B+ from a 20 amp breaker.
Oops! Even though it says B+ in the EWD, it is accessory/ignition on.
Sorry, I am struggling to understand what you are saying. Can you please rephrase?
Thanks!
The latch switch can be used? But there is no constant power? And how did you use the defogger?
The latch switch is just that a switch (2 wires) once disconnected can be used for your needs. In the factory wiring set up it is used to switch the negative side of the circuit and all of the dome lights/door lights are feed with a constant hot. <<If this does not make sense to you save yourself a lot of confusion/trouble and ask for local help.
Im from Arizona and none of my Land Cruiser have a rear view mirror so there is zero needs for a rear window defroster in my life or rear wiper for that matter.:)
Ok, that makes more sense. Use the wiring for the automatic unlock/lock as something else. Good idea.
A.
