Yes, upon further inspection defroster switches are great. They offer an indicator light when on, as I found out by testing today.
I actualyy came up with an even better idea, and then almost smoked my radio because of it. Here goes:
I am disconnecting the lines to my rear heater due to deterioration and no real need for rear heat, so...I got the idea to use the blower unit for the cooling air to my radio, especially since the duct is right under the console. This idea is great, and with a little redirecting of ducts will work well. But what did not work well was tying my radio into the fan switch. After firing it all up the radio lights did not come on and a slight odor began to fill the cab. You would think being an electrician I would have checked and seen that the fan is running reverse polarity. The radio did not like that.
After a few tense moments I swapped wires around and the radio came on and purred like a kitten! (whew).
So I still plan to reroute my rear heat fan to the console, but will add another power source for the radio. I think it will work like a charm.
