Confusing Hard Start on 91
*****Update***** just figured out that these are NOT the same part. I have a Circuit Opening Relay on the way from a used parts source. It was cheap enough that I don't mind having it on its way while I do troubleshooting. Can't get to it for the next few days, anyway. The Toyota part number is 85910-30050. Can search online auction sites for it.
Anyone able to give me a quick help?
New Information:
1) I pulled the cold start injector and it doesn't spray when the motor is cranked. It DOES spray when I put 12V on the injector terminals. Any quick guesses about where the wiring problem is? Thanks!
2) Finally got a volt/ohm meter in same place as the truck, and I tested the Circuit Opening Relay. According to the manual, there should be continuity between STA and E1; and between B and FC. There should be no continuity between B and FP. The relay fails the second criterion--there is no continuity between B and FC.
Ok, things are starting to converge. There appear to be two problems. Here is what I discovered. The Circuit Opening Relay is in fact bad. I did an unsafe workaround until the replacement comes in the mail--I took the cover off the relay and zip tied the solenoid contact down so that it is permanently on. This means that the fuel pump is running if the ignition switch is turned and could result in a fire in the case of an accident. But I now know for sure what the fuel pump sounds like (it turns on now with the key and doesn't have to wait for the AFM to tell it to switch on). So I know the fuel system is getting pressure at all times.
I also checked the Cold Start temperature switch. It appears to have the right resistance. So what I did was wire up a ghetto cold start injector circuit as follows. I took the cold start injector electrical plug off. I put two alligator clips on the terminals. Then I took the other ends of those alligator clip wires to the battery. I asked my wife to start it as she normally might. As she was cranking, I did my best impression of a pulse signal and kind of rattled one of the alligator clips onto the battery terminal, completing the circuit (you can hear it click) on and off quickly. The truck started right up no problem at all.
So I have the Circuit Opening problem solved, and I think that was just not helping because it wouldn't let the fuel pump turn on until the engine was running.
The COR problem was exacerbated by no fuel from the Cold Start Injector, which means that the truck is very unhappy about getting running and therefore getting the AFM to tell the COR to turn on the fuel pump.
So here is the (knock on wood) last thing to fix: Why is the cold start injector not getting signal to fire? Any help?
You could have simply used a jumper on the check connector on the firewall to run the FP, but its done.
The CSI has a time switch as shown in the schemo:
It's sort of a story without much of an ending. Here's what has happened. I was going to take it in to a mechanic to have it gone over and fixed once and for all. I needed it done quickly, and the recommended mechanics were all too busy to get it in. So I decided to do a few things myself:
1) I disconnected the plug from the cold start injector itself and hard wired it into the battery with a Radioshack pushbutton switch. When I was having a hard time starting and would have used starting fluid, I just thumbed that switch a few times. That would kick the injector enough to get the truck running. Sometimes it was (very) rough until it had been driven for a few minutes. I would even have to leave it in 1 or 2 to make sure it didn't stall. But once it got warm, it was great.
2) Installed new spark plugs. This seemed to have helped slightly.
3) Ran five tanks with the silver bottle of Gumout fuel injector cleaner. I drove it nonstop for a few hundred miles a few times with this stuff in the tank.
Now the truck starts and runs perfectly. I believe that #3 was the key. Although it is still possible that I was chasing an electrical gremlin somewhere, I believe I had clogged injectors and perhaps other gunk elsewhere in the fuel system. Before I had the truck, the PO had let the truck sit for 8 months over the winter. Following that, a friend borrowed it and put Slick 50 fuel system cleaner in it. I believe that the rust (or whatever) in the tank that had accumulated over 235K miles and a winter of idleness was dislodged by the Slick 50 and got stuck in the injectors. It took some driving and the Gumout to get that out. Again, I could be wrong.
