I am a newbie, but I have tried to do the due diligence in the archive before posting this plea for help.
Here's the situation: '91 FJ80 with 235k miles. Great shape and runs well. It's in Utah right now, so it's hot. I just purchased it two months ago, so I don't have a ton of experience with its quirks. After purchase, it ran and started fine. Over the course of two weeks, it has become increasingly difficult to start, cranking but taking longer and longer to catch. Now it is at a point where on every startup you have to give it a shot of starting fluid to get it running. After it gets running it is totally fine and driveable. Maybe the idle is a bit low, but it runs fine. I have gone through some diagnostics:
1) The EFI Relay was very hot, so I swapped it for one of the two left in the truck by the previous owner.
2) With old and new relays, the CEL comes on when the key is turned to the "on" position.
My hypotheses for what is wrong:
1) coked up injectors
2) coked up cold start injector
3) bad fuel pressure regulator (inspired by the great analysis in this post: https://forum.ih8mud.com/60-series-wagons/6464-3fe-fuel-supply-problem-i-fixed.html )
4) a startup flow relay of some kind
5) bad fuel pump
6) other: something that will make me feel dumb like a disconnected vacuum line or a clogged air filter or old spark plugs (now that I write the spark plugs, I kind of like that one)
I find a few things confusing about this. First, if it were a spark problem, the truck wouldn't run on starting fluid. But if it were a problem with the "normal" operating fuel system (fuel pump, fuel lines, ECU, injectors), then how come it runs fine after it gets a start assist from starting fluid? If it's something in the "startup" fuel system (cold start injector), then it seems like it ought to be able to start soon after it is turned off.
I'd really appreciate any advice. Thanks!
5) bad fuel pump
