Confirmed fit in '14 LX: Baja Designs Squadron Sport + Tacoma mounting kit
Just installed these lights in SAE and neither light is working. Double checked wiring, tried each light. Plugging in original fogs still works as well. Guess I’ll reach out to BD to see about replacement lights.
Did you try swapping the leads on the BD harness? Mine didn’t fire up either at first and then I switched the wires.
I’m going to try this over the weekend. Have had a ticket with BD Tech Support for a week now with no response as well.
Just installed the squadron pros spot/floods
Normal / high beam / bajas
Just installed mine, took about an hour since I was a little skiddish about pulling the bumper at first.
You can probably do it in less than 30 minutes if you're experienced
Thanks for the tips op, it was very easy to follow
Going to install mine this weekend. Thanks @eatSleepWoof and @Lummie for the detailed info! @Lummie - did you find it necessary to install the gasket tape around the edges to make a better fit in the bumper opening like @eatSleepWoof did? I don't know exactly what material that is, but it seems to fit ok without it.
do you have any confirmed fitment of Baja Squadron or Diode Dynamics with 2014 Toyota Landcruiser?
I have a 13 Landcruiser which should be the same as a 14/15 and my measurements of the stock fogs are very different than the patterns used for tacomas.
I did buy a set with some Tacoma brackets that I plan to make further adapter tabs for.. but it’ll be a while before I get that going.
Edit: not saying they don’t fit LX.. LC has larger fogs and that seems to be the fitment issue.
I ordered this kit from diode dynamics
SS3 LED Fog Light Kit for 2016-2022 Toyota Tacoma
Fits my 15 LX no problems. Super easy install
