Confer roof rack
Westminster
Has anybody ever been able to mount a roof rack like the one I have below while having a soft top? If the cost will be too much work, I might as well get rid of it!
at one time I had a conferr, I took a big piece of thick plastic and secured it to the floor, then poked holes in my bikini and installed it with some ubolts around my rollbar. You could do the same with a soft top and probably use some type of grommet, but it would leak a bit probably.
That sounds like the rack I got from cruiserbrett!:hhmm:
Conferr roof rack
Some heeps came with supports from the windshield hinges and from a mount on the rear of the tub. It wouldn't be too bad to fab something for the front (using the windshield hinge). For the back one could use a T bar from Yakima or Thule that mounts in a 2 inch receiver. That way you don't have to drill into your body. Or for that matter a 2 inch receiver front and back. I wouldn't mind doing the same thing. Good luck, Alan.
Quite a conundrum. I wouldn't want to put holes in my soft top either, nor holes in my clean 40. The double t-bar using a front and rear receiver for me was more for carrying 2 sea kayaks, and not a permanent thing. Would be interested in having a roof rack permanently though.
With a bikini top it is not a problem...
Just build what is essentially an exoskeleton and attach to low points on the roll bars. Then the exoskeleton will extend up and around and attach to the confer rack. You can use 1/2 inch tubing, as this is only a roof rack, not a roll cage.
Best,
T
