Computing track width
Santa Rosa, CA
Can you guys help me computing track width. I keep doing something wrong. Isn't the formula
axle width (WMS to WMS) + 2*spacer width + 2*offset(converted to inches)
I'm trying to back into the correct axle width for my 40 based on the actual tire position I want in the end. When I get a chance, I'll post my math. I'm trying the formula on my current set up and it keeps not matching my actual track width.
Because there are spacers on my setup now, so I have to include them to get the match to work.
I thought offset of distance from centerline (in mm)? Should I have backspace in the equation?
So, the fj60 axles I have on right now are 58.3" WMS to WMS. I've got 1" spacers. the offset on my wheels is -6mm or -.23"
Which computes out to 60.77". My actual measured track width (center of tread to center of tread) is 62". So, i'm close, but I'm not there.
I have fj60 axles in the rig now. I'm gong to dana 60s this year - I'm trying to figure out what width I need.
Ahhh, thanks. I'm going wider, but I don't think I'm going full width. Plus, people are running wheels with a lot more backspace now because it puts the contact patch more in line with the axis of rotation. So, I wanted to play with all that. I've been told, going full width with 5.5" of backspacing and you're equivalently narrower - that's what I'm trying to get the hang of.
Yes, I'm going to 40's and 8 lug (as I've been advised here) and I'm thinking about Hutchinson wheels. In 8 lug, they have 4.5" of backspacing. But they are nearly $500 a piece - OUCH!
