Compressor clicking on and off
Monroe, CT
i just replaced my compressor after my old compressor gave out. I had my system charged by a local shop. No leaks were detected. Why would my compressor turn on and off about every five seconds when the AC is running? Could it be a relay somewhere which shortened the life of the old compressor? When it comes to electrical issues I am kind of an idiot so any help is appreciated.
I will take it back to the place that filled it. On other vehicles people have reported a relay that caused this issue. Does anyone know where a relay would be located that controls the compressor?
Gotta put gauges on it find out for sure what is going on. Did they replace the dryer also? If not, the A/C place you took it to doesn't know what they are doing.
Corpus is a tough place to be without A/C.
I had the same problem after an overcharge, cycled every 3-5 seconds on and off. Reduced pressure to spec and worked perfectly.
I also replaced the dryer. All they did is recharge the system. I may be off on this but my fear is that this was happening before and destroyed my old compressor. I will have them check the amount that they put in.
Lower right corner of the diagram (A3):
A well bookmarked FSM is a thing of beauty
Thanks Malleus. I had them recheck the pressure and it was to spec. My next step is to find a way to check the pressure switch.
Not saying this is your cause, but I've seen a problem like this were due to age, heat, and vibration the wires connecting the compressor plug to the harness went bad. So when the customer would try the run his AC, vibration would cause that connection to short out, then his compressor would just cycle on and off. Since you just changed your compressor, and had to handle that plug, can't hurt to check that connection.
I had the same issue with it short cycling when I attempted to recharge it. Best way to recharge a vehicle is weighing in the freon. There should be the exact amount listed on a label fixed under the hood. Recovered the refrigerant, pulled vacuum, and weighed in the charge using a scale. Everything worked fine afterwards.
