Compression Test Result Help
As some of you have read in my thread below, I am looking at a 1978 FJ40 with a stock drivetrain. Thanks to suggestions below, I had a mechanic take a look at the rig and do a compression check. I'm still waiting for the report to get the exact numbers but he told me the compression readings averaged about 120; however, two cylinders read 90 & 100 (I believe the highest was 140ish). I'll edit & post the exact numbers when I get them later today. How bad is this reading? I know the factory spec is all cylinders within 10% of 150. Am I looking at a swap/rebuild pretty quickly? I haven't driven it yet but the mechanic says it drives fine.
Lastly, the current owner says he is having cooling problems in traffic. Could these be related?
Thanks in advance,
Lance
Factory spec for compression is:
149 psi standard
114 psi limit
and less than 14 psi difference between cylinders.
Do a wet compression test to check whether you're dealing with rings or valves. An increase in compression figures point to rings.
Your mechanic will know how to do this.
Thanks. The actual readings were:
1-128
2-120
3-90
4-150
5-100
6-120
These reading and evidence of a general lack of maintenance (leaks everywhere, needs knuckle rebuild, frame rust, etc) made me decide to keep looking.
It's hard to be patient. . .
Thanks again,
Lance
Sounds like p/o neglect put a hurtin' on that ride. Try offering less $$. You may get it for a steal now that you know that it's tore up. I'd hate to see somebody get ripped off on e-bay with that thing. It sucks i tried it -once!
I agree with you regarding the ebay thing. Looks to me like the PO just drive it with zero regard to maintenance. I passed on the rig am still looking.
Thanks,
Lance
wise move not to hurry in. There are lots of nice cruisers out there.
