Compression numbers above 150
Australia
Hi there,
Did compression on the Cylinders and below are the results. Truck has high mileage 580,000 K ( 360 000 miles), 1fzfe, manual gearbox
  • C1:150
  • C2:183
  • C3:176
  • C4:152
  • C5:176
  • C6:160
Is any engine work required based on above numbers ?
I have heard 15% difference among the cylinders should be fine. Isn't that the case?
No
Cheers
Your math also isn’t mathing
Your greatest spread is 33psi.
Cheers
Did you check with engine warm or cold? If you want to know if your issues with the lower compression is top or bottom end do a cold and warm compression then add some oil after to do a wet compression and see the difference in pressure. Make sure battery is fully charge or on a charger.
Skip all that and do a cylinder leak down test. Or do both but cylinder leak down don’t lie.
