Component Speaker Install - Factory Appearance
those tweeter grills are nice. strong work! dont' want to jack the thread, but anyone know where i can get some factory grills in the same color for the front speakers? the PO popped the original ones off the front doors and wasnt sure if i could get new ones separately or if i would have to order a whole door panel. i'd be willing to "glue" one on if i could find a pair or even something close (i.e. tundra or sequoia grills...)
Cruiserdan, Cruiserdan and Cruiserdan would be the first three choices I'd make for your source.
Nice Boyd. I like the full factory look you've maintained.
Here's where my installer put tweeters in the door.
Brent,
That's pretty creative. Was yours the one with the center channel mounted to the back of the rearview mirror?
How did you attach the speaker grill? Since you removed the particle board in which the tabs mount to.
I cut off the tabs and used loctite glue for plastics to glue the grill directly to the door panel. I also used weatherstrip adhesive to glue the door trim to the particle board so the grill wouldn't float away from the panel.
You might also try cruiserparts.net for used parts.
Brent,
Yes - they installed two small speakers in the back of the rear view mirror as a center channel. They reflect off the front windshield and give a very nice concert hall effect.
After installing my Quarts, I've got a good feeling why they put in the center channel. Although they did mount your first set of tweeters in a different location than mine.
I've been contemplating bringing the rear tweeters to the front, but I still need to figure out where to put them while still looking stock. I prefer a stealth, stock look.
The grill may eventually fall off. If it does I have a solution for you.
