cold weather starting difficulty
My '72 fj with the original 6 in does not want to start on cold days. The choke is in good working order, but she just rolls over&over just like there is no fire, then all at once she cranks up. What can be done? Any ideas?
Thanks,
sawatcher :confused:
Everyone finds their own starting ritual that works for them. My 77 FJ40 wants full choke and one or two pumps of the gas pedal before I crank it. Then she fires right up.
If you haven't had a problem until recently, run through some standard checks (battery, starter, etc). There are plenty of threads on starting issues if you do a quick search.
Good luck!
I had this problem once. When I parked the cruiser on even a slight up-incline it would take a long time to crank before starting. The diaphragm in the fuel pump had a small hole on it allowing fuel to empty from the lines through the pump back to the tank or into the crankcase:eek: Anyway, replaced the pump and no more starting problems.
GL
Ed:beer:
My '69 gets almost got addicted to starting fluid until I made a dwell and timing adjustment. Seems to like 10 degrees btc in the winter. Also I adjust my valves once in the fall and again early summer. With these solid lifters it makes a big difference. JD
Dollars to donuts, your accelerator pump is not working.
Mark...
And on some carbs, at least, the bowl can drain itself if you leave it sit for a few hours. My 2150 does it and it annoys the hell out of me. Not sure if the Aisin is susceptible.
Mark...
I'd be willing to bet 2 chocolate crullers (w/ sprinkles even!) that mark is correct. :D
One of our local Cruiser Pac Members has early morning winter starting issues.:mad: It was diagnosed to have low cold compression down syndrome, not producing enough vacuum to draw fuel into the mixing chamber.:crybaby: A shot of either gets her going for that early morning wake-up call, after that, all is fine unless she gets cold again.:eek: A fix is in the cross hairs, but has to wait till the ship comes in :grinpimp:
When is the last time you adjusted cleaned or replaced the points?
I have noticed with my fn F that keeping the points healthy can help in starting....
Yep, poor points will creat weak spark which can lead to difficult starting. I'd still check the accel pump first though.
Mark...
