Cold blooded.
that's what you get for buying a new one.
j/k
Could you drill the shaft out and plug weld the hole?
It would be a lot of drilling, but you could do it. I wouldn't bother to weld the hole. I'd make covers that go in place of the bushings. Each bushing is made with a plate and one screw holds it to the casting. You could weld up the hole in the bushing easily enough. If you were paranoid, you could further seal it with JB Weld, but it's probably not even necessary.
I looked at it again last night. There's not a lot of room to get in there with a hack saw. A long, straight torch attachment would work, but I've never seen one before.
I'm leaning towards leaving mine alone now.
I think Degnol posted his home made heatriser design a few times as well.
Not the best pic, but the best one I have on this computer.....Sorry its not bigger, but I've been saying that all my life.....:D
It does also show the liqiud heatriser underneath the carb.....
Ed
Ed
Any specifics on how you made it? P/N's etc?
Now I've just got to figure out a better way to cut it out than a hack-saw blade with a duct-tape handle. On a '78 manifold it's about 6" to that shaft from either end of the pipe. Some kind of power cable saw that I've never seen would work great. I have to cut it twice too.
Just recently overhauled a '71 F exhaust and reworked the heat valve. Use a die grinder with a burr bit to grind off the weld. Remove the shaft clips (if they haven't rusted away already), the coil spring and knock the shaft out.
Leon...
I think the later heatrisers were further up in there than our 71s, but maybe you could get in there with a dremel pencil extension and the right bit.
Here is another pic. I just begged a short piece of aluminized muffler pipe, I think it was 2", and made a shroud-type piece that fits around the header tube by making an eliptical bologna-style cut then welding a collar to it at an angle. The collar is fastened to the header tube with a hose clamp. A short piece of 2" pipe is slipped inside the aircleaner opening, secured with a hose clamp and the two are connected with some of the accordion intake hose.
Sounds more complicated than it is.
I will make another for you if you want. I think I made one for someone else, but I don't remember who.:doh:
This time I'll take pics. It is really a 1/4 bananna job.
Ed
Thanks for the offer but now that I see it I don't think it will help me much. I do not have a stock air intake, just a K&N filter on a Weber carb.
The liquid heat riser might help.
I scoped the intake out this morning I see the four bosses that are tapped into the bottom of the intake and assume that is where you bolted some kind of small radiator. Maybe like an ATF cooler?
It is a plate of 1/2" aluminum tapped for pipe thread with some elbows and barb fittings. Coolant runs from the head to the fluid heatriser then out and over to the heater valve.
The warm air intake is helpful, especially to prevent icing of the carb at about 35*
GL
Ed
GL
Ed
:idea: I get it.
Thanks.
attachment.php
I think this picture of Ed's setup is helpful, too.
attachment.php
Have you nothing better to do than to go through my underwear drawer looking at old pics?:D
Ed
attachment.php
That makes it a lot clearer. Some kind of gasket between the plate and the bottom of the manifold I assume. I was thinking it was just a hole through the plate with a fitting on each end, as well as Aluminium transfers heat I bet that would work to.
Rusty....do you want the display model? I am not currently using it. PM me if interested.
Ed
Well actually, no.
Dave....................................you crack me up:D
Thanks for posting. I lost several pics in something called "Old Computer Backup"
I have found my way there before, but evidently did not leave a clear trail of bread crumbs......:doh:
Ed
Ed
I think I've come up with another plan. I still need to do some research, but I would still use an aluminium plate bolted to the manifold.
