I'm gonna have to give this a shot.... I live up here in Alaska and it's gotten to the point where my wife doesn't want to take the Cruiser anywhere in the winter! I'll post up my results also.
Well, plugged the AC drain hose with not much change.
What I did do that had a major impact and pretty much fixed the problem was to put foam weatherstrip up between the firewall and inside of the passenger side compartment just above where the carpet ends.
The foam piece was the 2-1/4" x 2-1/4" that I cut to approx. 12" and stuffed up there. It isn't pretty but almost impossible to see.
I purchased the weather strip at Home Depot but am sure it is readily available at all hardware stores.
Cheap fix for $5 and the wife is happy now!
View attachment 1910206View attachment 1910207View attachment 1910208
So its winter again and wife started complaining abt cold draft again. I pulled off the glove compartment and even unscrewed the ECU and felt around the main trunk that brings in the outside fresh air. I did this while my wife drove at abt 55 mph
Pic 1 below shows the air set on recirc. At the position the gate closes the trunk and no cold draft comes thru
Pic 2 shows the non-recirc position. The foam covered gate is expected to seal up the square opening but is no longer air tight!
I believe the solution @Burch1 posted above works because it blocks off the whole section from the cabin. But i also believe it kills the recirc function since the square opening is now actually cut off from the rest of the passenger compartment.
Set on recirc
Set on fresh air (that where the old foam seal leaks)
Here we go, I spent the morning chasing down why my wife's feet get cold when driving down the highway.
I believe I found the culprit!
THIS MAY NOT FIX EVERYONE'S ISSUES, but I do believe it fixes the issue associated with the origin of this thread.
I removed the glove box, the black upper Instrument Panel Knee Bolster (55433C), unbolted the ECU (not disconnected), in the attached pic look towards the firewall just above the recirculator vent servo (red box). When driving down the road you can feel cold air flowing from this foam edge. It appears this plastic sheet is supposed to be flush with the firewall, but due to age is pulling away farther than what the foam can compensate for and there are no retaining clips to maintain a flush fitting.
This was a very hard part to identify but I believe it is Engine Compartment Insulation Apron (55210-60084).View attachment 2170029
To fix it; I cut a ~8" strip of foam (1.25" x1.25"), shoved into place, and taped in place with duct tape spanning from the wall to the apron (see below pic - taping was not easy or a clean application).
I drove the car and it appears to be fixed. However, with a gremlin issue like this, air pressure will always find a way. I had to then tape a seem between the recirculator vent housing and the apron as well (green arrows indicate the seem - much easier application).
Hopefully this works for you too!
I have a small wad of duct tape helping apply pressure to the cabin filter cover. That cover seemed to affect the cold air problem I had as well. I have no idea why Toyota didn't design that to have a tighter fit.I kept feeling around until I noticed the air filter cover leaking cold air!! The freaking cover is not snug in its place is leaking cold air in the cabin![]()
One temporary fix is to set the recirculation button to "recirculation". It will stop the outside air from coming in to the cabin footwell. It's not a perfect solution as you may have to switch it back for a little while if the windows start fogging, but it will mostly solve the short term problem.Riding shotgun with @Str8Razor to Telluride Colorado on a snowboarding trip in his 03 lx470 and my feet are freezing stuffed my jacket into the right cornerfor now and is helping but hopefully someone figures this out no way i can fix this on this trip but damn its cold af!
Have done that already no worky worky in this situationOne temporary fix is to set the recirculation button to "recirculation". It will stop the outside air from coming in to the cabin footwell. It's not a perfect solution as you may have to switch it back for a little while if the windows start fogging, but it will mostly solve the short term problem.
