Coil Questions
Vt
Hey Everyone,
I have read over the threads on 40 series coils and I cant find the info I need. I am putting my 1975 40 back together after five years and the labels have all faded off my wiring. What I need to know is where to plug the white wire with blue stripe that has power only when the key is turned to start(starter engaged). I have been scratching noggin over this.
I think the WL (white/ light blue stripe) goes to the B+ on your alternator. Maybe post up a pic of your harness.
Here is a pic of the 76 harness I have showing those connections.
Red to the distributor from the OEM igniter which you no longer have
Yellow/Black to oil pressure sending unit
Black/Yellow to starter from + side of coil (This is the ballast resistor bypass wire)
Black to - side of coil from OEM igniter
If you truck is running now how is the Pertronix wired? Draw a pic showing how the PO has it connected and post it up.
