I just did the paper clip test for my check engine light code. and it seems to be code 52. (knock sensor) How common is that and bad? also where is the knock sensor and how do I repair that?
Please check again.I just did the paper clip test for my check engine light code. and it seems to be code 52. (knock sensor) How common is that and bad? also where is the knock sensor and how do I repair that?
Please check again.
There is no code 52 in the FSM, and the 3FE doesn't have a knock sensor.
For your reference.thats what I thought... guess I suck and counting flashing cel s haha. hummmmmm its raining now. Ill get back when I can on this one.
LOL, that's what I thought.I think I was reading the codes backwards. 1.. 2 .. 1..2..3..4..5. then code 1..2.. 1..2..3..4..5..6 So I am guessing thats code 25 and 26?
Likely O2 sensors.
yeah... darn. thats what I was thinking too. I actually had to replace a cat and down pipe because the previous owner for some reason welded the o2 sensors in and it was a horrible job. exhaust was leaking out of a hole about the circumference of a pencil. I replaced the o2 sensor when I did that. it must have been stick welded. unfortunately only the one was leaking so I only replaced one sensor. I am guessing the other O2 sensor in the other down pipe is causing the issue. unfortunate because it too is welded although looks like a much better weld. Weirdly I drove it with the hole like that on a 6 hour trip back home with no check engine light. when I bought it. but I guess the o2 sensor was still good. was hoping to avoid that one for a while. I think Ill see if I can get to summer before replacing that one. and Just live with the CEL for a while.
6 Cylinder 1991 TOYOTA Catalytic Converters
www.discountconverter.com
I have purchased replacement downpipes/converters from this place. They are a bolt in replacement with O2 sensor bungs and cats.
