Code 11 and Location Of ECU Ground
Blue Ridge, VA
Warning...electrical diagnosis is not my forte. I have a 90 FJ62. Check engine light came on and diagnosed code 22 (water temp sensor) and code 11 (momentary interruption in power supply to ECU). Fixed/replaced the temp sensor. On to the ECU. Ran troubleshooting from FSM pages FI-30 to FI-32. I showed voltage in all circuits (step 1 of each). The M-REL to E1 was a little low but I suspect it may be my technique.
I am thinking of checking the ECU ground (the harness). Where is that located? Also where is the EFI main relay located so I can take a look at that ground as well? Anything else I should look at? Finally, is it OK to drive around with this issue? I don't want to get stuck somewhere. Thank you.
Edit: I located the EFI main relay. I should have checked FSM first...
Edit #2: My issue has morphed into something similar to Walrus and having issues with starting/idling. It will start and then whimper and die. Trying to add gas only hastens its dying out. Have checked most of the items suggested in this other thread. I have come to a point where the FSM has me doing the following...."check wiring between ECU terminal and body ground." Page FI-33, dealing with the FPR.
So, my same basic question...where does the ECU harness get grounded? Is it somehow tied into the chassis frame grounds? Appreciate any assistance.
Thanks. That did help. I cleaned it up, was connected, reattached and code 11 is gone. However, now I get three new ones. 22 water temp sensor signal....why, I just replaced it previously. 24 intake air temp sensor. Troubleshoot per page FI-36 and there is voltage between the two terminals. Last, code 31 air flow meter signal. That checks out ok per page FI-35. Might be time for a trip to the shop. Still conks out after starting.
Can someone enlighten me on what the fix for this was? I've read both posts and I can't seem to find the answer. After 30 minutes or so of driving, CEL comes on and throws a code 11. I have the FSM and know what it says, but it just says check. What should I be looking for? Thanks
Did you ever find out the issue? I’m going through the same thing.
