CO2 Tank Options
North Jersey
I searched for some CO2 tank options and brands and found mostly storage locations and the CO2 tank vs on-board air debate. I have 33's and don't expect to go any larger than a set of 35's for wheeling and was wondering what would be the best size and brand to get. I've been looking at Powertank, Ultimate Air, and Outback Equipped, and I'm a bit lost on what I need and could use some help.
Thanks
George
Best deal I found was a "source" sport 10lb brushed aluminum tank with regulator, hose, bracket and plastic guard. It works fine for my 33' tires. If I were to do it again I would go with a 15lb botttle.
All the brands are the same thing effectively. Maybe some differences with cool gauges, maybe some different handles and regulators but at the end of the day they are all the same thing. I have used my 10# surprisingly often. Although the 15# would last longer, I have never used more than the 10# during a trip and that was using it on a 2 week trip to Yellowstone the long way. I got my set up from Mark's Off Road for $220 for a 10# Source package.
I think my setup was around $120 from my local industrial welding supply. 20lb tank, fixed regulator (150 works well), fittings and poly hose (don't do nylon). For fills, they swap bottles for $10. No waiting around. Yields about 20 tire fills. Course it isn't painted all pretty nor is it dipped in bedliner for that rugged outback look. ;)
Good lord! I took a peek at what Powertank is selling their stuff for. Don't waste your money imo.
ESH has a point. I COULD have gotten everything through AIRGAS for just over $100 but then my bottle wouldn't look all pretty :flipoff2:
And as long as you are thinking about a tank, think about how you are going to store it in the vehicle. I still have that issue because I am planning on drawers but what do I do with it in the meantime? And I don't want to make more holes then I need to.
Also after voiding the tires of air and refilling repeatedly, I would plan on making on of these:
Slee - BiFlate Air up tool
Just more things to plan on. Plus when you refill you can go to any bar/beverage supply house to refill the C)2 for $10. So it all adds up pretty quick.
Would a 20Lb. tank be overkill and be a huge freaking thing to carry around? I'll probably use the tank 5-6 times a year. Looking at the tanks it does look like a lot of flare for just a CO2 tank just wondered if one had better gages then the others. I made a QuadFlate setup last summer didn't see that Slee had plans for one. I can air-up or air down all 4 tires at once. It has a gauge, ball valve, and four machine crimped hoses with locking chucks screwed into a aluminum manifold. I went to a local pneumatic/hydraulic shop and made it up for about $120.00
Don't overlook the possibility of laying the tank down (alongside or secured to the top of the drawers?). The tank only has to be vertical to use -- not to store or transport. Mine is a 20# tank left over from my home-brewing days. The 5-gallon soda keg goes along with me (also laying down) and gets connected to the CO2 tank for a power wash.
My tank is seldom in the truck except for off-roading, and is strapped behind driver seat to seat anchor for easy removal (and use on the trail). In background are my drawers (stacked, rollered, sterilite underbed storage) and spare tire strapped to 3rd-row seat anchors. Yeah, I know, what kind of off-roading can he do with those stock Michelins -- dang things just won't wear out!!?!
#10 lbs will get most of us by IMHO. #15-20 becomes a little more of an issue to mount/store. If you have a convenient place to refill you can get away with a smaller set up. Having read lots and lots here and as has been mentioned in this thread also, you can put your own system together cheaper than any package from any of the commercial systems. The $$ is in the regulator. Don't skimp there if you build your own. IMHO, Powertank is very expensive. I did a group buy several years ago with The Source tanks. I've been happy with my #10 lb set up. Pic of my mounting solution is the intro pic here: IH8MUD Forums - View Single Post - FAQ for 80/LX450 - May, 2009 - Added ROTF
Joey, other than a modest time saver, I'm struggling to see the benefit of a BiFlate system.
Any insight to a list of advantages?
-KK
CO2 prices
Not sure why it costs more in San Diego but air gas charges over $20 for a 10# refill while you wait so does the local welding supply company.
-KK
They have been around for a long time, Rodger Brown has a page about them. IMHO more trouble than they are worth, a pain to deal with, store and have to carry another hose to run air tools. I air down by removing the cores, it's the fastest way that I have found other than cutting the sidewall.:hillbilly: The 4 way air maybe slightly faster on air up, but by the time it's untangled and stored I'm done, so not a big deal.
2air/4air Tire Inflator - Deflator
After having the Puma compressor, I would never go back to the CO2 bottle payment program.
Do you guys have Seals Compressed Gasses in SD? Last time I filled my 10# there it was $12.
Boy that sounds famillar ;)
Quad manifold is the joint. Airs up/down all 4 to the same pressure, coils around itself with a velcro strap, fits into a storage box. No muss no fuss. Never leave the pavement without it.
Tools
I checked out the Puma and it looks like my answer! I had no idea that there was a decent size 12 volt compressor out there, might be a bit slower but as long as you have a running truck you're in business.
Kudos to John for showing me his setup, I admit i copied from him. Thanx John
it's all good.
You need to check where you can get tanks filled in your area before committing to this type of setup. I was not able to find places that were open on weekends or past 5pm on weekdays to get tanks filled. Makes it hard if you work for a living.
it's all good.
I was going to ask you if there was a place near us for refills, but I think the 12volt 1 gallon Puma compressor is more than adequate for my use. I would love to have the OBA system you have but I have emission junk in the area where the compressor would mount.
