Clutch Slave Question
Virginia
Just ordered a new clutch slave from SOR. Aftermarket. Before I install, do I need to tear it apart and lube the piston with grease or do they come already greased?
I know I can ask SOR, but I figured I'd ask here first.
Thanks
Thanks Coolerman.
I saw elsewhere on this board that lithium grease was advised on those seals. I like your solution as I am much more comfortable not taking this thing apart and just installing and bleeding.
Last clutch slave I installed I disassembled and HONED. I got a piece of scotchbrite and put it on the end of a drill, lubed that sucker up and honed a nice cross-hatch into the walls. Since I only had snthetic bearing grease, I coated it all with that, intalled and ran it.
It has only been in there a month, but I have had no problems with it.
I realize I was being waaaay to nitpicky about it, but I'm obsessive complusive and had NO choice in the matter.
I would put a little grease on the inside of the rubber dust boot to keep the plunger from sticking to it.
