Clutch Replacement
1987 FJ60
Dropped transfer and transmission successfully. Thank you @Poser for the great write up.
Looking at clutch housing cover, does that come off in order to remove the clutch cover and replace clutch, bearing, etc? Or, can I remove the clutch cover etc, with that in place?
Long term goal is the RMS replacement.
Thank you, Tim
I’d remove the bell housing (clutch cover), makes the clutch, flywheel and RMS seal replacement much more enjoyable :).
Just did this recently. Left the bell housing on throughout the entire event. Not sure how that would affect replacing the rear main seal. I dropped the oil pan for a re-seal at the same time, so the RMS was a breeze.
Yes, makes sense. Definitely a personal preference topic. I like to have a good look around while in there plus it made cleaning the inside of the bell housing much easier as I had some gunk buildup from the leaking.
pressure plate, clutch disc and flywheel all drop out thru the bottom of the bellhousing
you cannot remove the bellhousing without removing the above parts first
rotate flywheel to remove bolts holding the pressure plate to the flywheel
