Clutch Question
Arkansas
The clutch on my 76 FJ40 is working fine. No slipping, no leaks, and the pedal height is fine. The problem I have is that it engages about an inch above the floor. You can hold the clutch all the way to the floor and as you come up slightly it quickly engages and takes off. I have read allot of the threads and can't find exactly what I'm looking for.
Is there an adjustment I am missing? Is it an adjustment at the pedal, clutch, master cylinder, or slave cylinder?
I just need it to engage at a higher point than just off of the floor.
Thanks for the help!
Clutch pedal height should be 215mm or 8.46" at rest from the angled floor board. free play should be 1.0 to 5.0 mm. These adjustments are made under the dash at the push rod.
Release cylinder fork end play should be 4.0mm to 5.0mm at your clutch fork and rod end. Hope thids helps some.
Rob
Is this a new problem or something you have been dealing with for a while? Try the above adjustments first.
I would bleed the system if the above adjustment doesn't help you. Air in the system could cause a need for more pedal travel to disengage the clutch (engage/disengage point too close to the floor).
If the clutch is new, the height of the pedal at engagement will increase as the disk wears.
Actually, this 40 is new to me and I am in the process of checking everything out and repairing what is needed. Clutch isn't very old. It just engages too close to the bottom. I was hoping there was an adjustment to make it engage at a higher point. This may be very simple and I am just missing it.
As for the pedal, the height is fine, it's just the point of clutch engagement I want to change.
Thanks!
When I got my FJ years ago, someone had changed the push rod on the slave cylinder. It was causing me problems and was not adjustable. Once I got the proper push rod for the slave cylinder it worked much better and was adjustable. Also the prior piece the PO put in there was slightly bent and it would kink or crimp (however you want to describe it) in its seated placement. It worked, but was much better with the rounded adjustable pieve from $pecter
I found time today to bleed the clutch. I first got a bunch of dirty fluid out so I bled it until everything ran clear. The pedal would pump up and get tight but will not stay. It returns to the point just above the floor as before.
So I guess since my Slave Cylinder isn't leaking and it appears to be working fine, and the fact that the clutch won't hold anything higher (but will pump up and act like normal for a little while), that the master cylinder is going bad.
Am I right? Or could it be something else?
Bump!
Where are all the clutch pros?
Yes, that would be my guess. The fluid is leaking past the piston. You should be able to adjust the pushrod to get the engagement where you want it in the pedal stroke. Since you are not having any luck with that, and the engagement returns to the bottom of the pedal stroke, I would say you need a new master.
Good luck!
:cheers:
Thanks Freak! I bled it again and the adjusted the push rod on the slave cylinder. Seems to be working fine and the clutch engages at a higher point now. Just what I wanted. Thanks!
Finally found a thread with the same issue. Mine has done this 4 times now in the last 2 days. Just started, glad I caught it before it left me stranded. I ordered a replacement Master & Slave forom @beno . Luckily, I have a '76-2F in my rig. Will have a SS lne made up from a local hose shop. SEARCH paid off.
Hi @pektonkristen, mine is doing same symptoms as yours.i have a complete new clutch system from Toyota in the garage, hoping in dont need it all. did you end up replacing just the master cylinder, or was this only a bleed and adjust linkage/rod at firewall situation?
