Okay Here Is The Problem And I Will Be As Specific As Possible. Several Monthes Ago I Began To Find That When I Stopped At An Intersection I Could Not Shift Into First Gear To Proceed. This Got Worse And Worse Until It Affected All Gears. I Had To Turn Off The Engine Shift Into Gear Put The Clutch In And Then Let It Out To Go Forward. I Then Replaced The Cluth Master Cylinder And For About A Month It Worked Perfectly. Then After A Day Of Wheeling It Sudenlly Became Impossible To Shift Into Any Gear. I Then Replaced The Slave Clutch Bled It And Nothing Changed Except At This Point Even With The Engine Off When I Put It Into Gear The Clutch Would Not Work And The Car Would Jump Forward When I Turned The Key As If The Clutch Were Not Used. Any Help As To What The Problem Can Be Would Be Deeply Appreciated.
