Clutch pedal won't work
Leesburg, GA
The cruiser has been sitting up for a few months. Went out today to work on her a little and the clutch pedal will not move at all. Any ideas? Thanks.
did you try it with the motor on or off?
USE BOTH FEET! :flipoff2:
Time to replace it. Anything that would have caused this bad of a lock-up has pitted the cylinder wall too severely to even safely rebuild.
FJ40onNOS said:
did you try it with out the motor on or off?
WTF?
Its either the pedal linkage, clutch master, or perhaps the clutch slave. Most likely the clutch master piston or slave piston has frozen-up inside the cylinder bore from moisture/rust/etc.
Fixed that problem. Now time to try and track down the wiring gremlin. Cruiser runs fine until you turn on the lights. Then it just dies.
I've had a similar problem with a weak battery or bad alternator. If those things are good, you have to just start tracing the ignition and lights wiring to see what's going on.
Suggestion: You could start the engine and then run a jumper wire from the battery to the "+" side (Ignition side) of the coil. Then turn ON the headlights. If it continues to run, then you likely have some weird wiring/ground problem. If the engine still dies, you likely have a weak battery or charging system.
Thanks for the suggestions. I will try and track it down today. I hate dealing with electrical problems. I dont trust anything that I cannot see. Thanks again,
