Fuel gauge reads empty.(really,it has gas)I thought perhaps connection at tank.Pulled wire.No change it gauge reading.This is a Poly tank.Pulled the sending unit/float assembly.Wasn't stuck in the down position.I was dropping off some serious ledges on the day I noticed this problem.Pulled the cluster and it appears the board is fine.Pulled the round connection for the electrical and tried to clean it as best as possible.I am not gifted at electrical.I also appear to have no Temp gauge.It's never run quite that cold.
Does anyone have any ideas on what I'm missing?Pulled fuse box and cleaned it well.Had plenty of mud slung under there.It appeared the copper loop on the circuit board is intact.Any thoughts would be appreciated.Thanks.
