Clunk In Front End
When I steer my FJ40 to the right in 2WD there's an audible clunking sound comeing from what seems the right front end.I'm guessing the infamous Birfield. I've checked to make sure the hubs were unlocked. Any ideas?
I had a good clunk up front and decided it was the tie rod ends. The clunk would only occur when I was turning hard and accelerating from a stop. If you're also feeling that the steering is a bit sloppy, loose or you're having to "correct" more than you should have to.. you may want to check there.
