****CLOSED****
With tax returns burning holes in pockets it seems like the perfect time for a group buy.
Who's in?
DISCOUNT CODE: ih8mud
15% OFF KITS, 10% OFF FINISHED
Buy here:
4X4LABS
Shipping begins mid May 2016
More details on the front bumper: Jose's thread
Front bumper facelift: AOE to 4x4Labs
Pre Discount Pricing and Parts
80 and 100 series bumpers and bumper kits
(40, 55, 60 series bumpers are identical price although some parts in the list below may be different)
Front Bumper $600 kit, $1250 built and powder coated
You will need to specify winch make and model when ordering on the website
Basic bumper- kit $495 Welded and finished $895
1 main bumper shell
2 sides
2 side top tubes
2 recovery points
Towing crossmember
Receiver
Single swing out bumper- kit $895 Welded and finished $1375
1 main bumper shell
2 sides
2 side top tubes
2 recovery points
Towing crossmember
Receiver
1 large spindle assembly
1 swing arm assembly with 4 sleeves
Latch and latch plate
1 gas strut with ball stud
2 stoppers
Double swing out bumper- kit $995 Welded and finished $1495
1 main bumper shell
2 sides
2 side top tubes
2 recovery points
Towing crossmember
Receiver
2 large spindle assemblies
2 swing arm assemblies with sleeves
2 gas struts with ball studs
3 stoppers
Tire holder- kit $125 Welded and finished $225
Swing out clamp bracket
Main upright
2 gussets
Side clamps
Top cap
3 hole tire holder
Square tube receiver
3 wheel studs
3 lug nuts
Hardware
One, two or three gas can- kit $195 Welded and finished $395
Main upright
2 base gussets
2 tubing hoops
Tube spreaders
Bottom plates
2 basket gussets
License plate bracket
Hi-lift bracket with standoff
Ladder #1 – kit $150 Welded and finished $350
2 Base tubes
2 rungs
Ladder #2- kit $175 Welded and finished $375
The first rung on this ladder is sleeved for a third accessory.
Main hoop
1 round rung
1 square sleeved rung
Cooler basket- kit $225 Welded and finished $425
Main upright
2 base gussets
2 tubing hoops your supplied dimensions
Tube spreaders
Bottom plates
2 basket gussets
ARB fridge basket- kit $225 Welded and finished $425
Main upright
2 base gussets
2 tubing hoops
Tube spreaders
Bottom plates
2 basket gussets
Bicycle rack, 2 bikes- kit $195 Welded and finished $295
Main upright
2 base gussets
Rear tire plates
Rear tire plate cross member
Rear tire hold down straps
2 skewer tubes
2 skewers
Safety hook
Top cap
Logo plate
Separate bumper parts
Main Shell- Formed and plasma cut bumper shells for FJ80 and FJ60 $185
Uncut formed main shells 72″ wide- $125
Formed laser cut side skid plates- $125 ea
HD Spindle assemblies- $95 ea.
Swing out assemblies- HD spindle assembly, sleeved swing arm with gas
Gas shock, ball studs and stops – $225 ea.
Accessory bracket clamp- $25
Towing receiver- $25
Recovery points- $30 ea.
Hi-lift bracket- $25
License plate bracket- $10
De-sta-co 4000 lb. Latch and latch plate- $95
Gas struts 120 lb. $25 ea.
Ball studs $2.50
6″ or 8″ Gusset $9
Accessory carrier retrofit sleeve/clamp kit- $29
Who's in?
Buy here:
4X4LABS
1 main bumper shell
2 sides
2 side top tubes
2 recovery points
Towing crossmember
Receiver
1 main bumper shell
2 sides
2 side top tubes
2 recovery points
Towing crossmember
Receiver
2 stoppers
1 main bumper shell
2 sides
2 side top tubes
2 recovery points
Towing crossmember
Receiver
3 stoppers
Main upright
2 gussets
Side clamps
Top cap
3 hole tire holder
3 wheel studs
3 lug nuts
Hardware
Main upright
2 base gussets
2 tubing hoops
Tube spreaders
Bottom plates
2 basket gussets
2 Base tubes
2 rungs
Main hoop
1 round rung
Main upright
2 base gussets
Tube spreaders
Bottom plates
2 basket gussets
Main upright
2 base gussets
2 tubing hoops
Tube spreaders
Bottom plates
2 basket gussets
Main upright
2 base gussets
Rear tire plates
2 skewer tubes
2 skewers
Safety hook
Top cap
Logo plate
Ball studs $2.50
6″ or 8″ Gusset $9
