Climate control question
Misery's feed trough
I have the "auto" climate control unit which I don't like. I did try the A/M switch on the back - when you switch it to manual the recirculate light doesn't function. You can hear it turning the flaps but the light doesn't change.
I figured I'd try swapping in a manual unit. I did this and everything works except the A/C button (no light & no air). Has anyone swapped a manual unit into their CC vehicle? I don't know if I got a dud unit or it will be this way on all of them.
I haven't. I just press the auto button (goes yellow) on mine and its in Manual mode.
Mine still makes some changes even when the auto button is yellow. For some reason it will switch to recirculate on it's own. Not that it's a big deal but I'd rather have the thing stay where I put it.
Mine will takes back control of the fresh/recirc upon every start, after I hit it once it stays where I put it until the key is off.
Is this how yours behaves?
x3 same here
X4 here
Mine will change from fresh to recirculate on its own. This is after me clicking it to the position I want when I get in. I did verify this today. It also changes from floor to dash vents, etc. when you change the temperature slider.
Anyone want to take a stab at my question about the A/C button?
I'll update the thread for the record. I tried another manual unit and the A/C button is non-functional as well. It doesn't look like a manual unit will work properly in a CC equipped vehicle.
