- Joined
- Apr 29, 2013
- Threads
- 52
- Messages
- 547
So most of the time in Texas, it's hot as sh!at and I've left the internal temps at either LO or around 68-70, even during the winter.
A few times I've noticed this winter, when I need as much as heat as possible, and I crank the blower speed to hi, barely any air is flowing out.
The rear seems to be fine.
What I've noticed so far is if I set the blower speed to high, and if the temps are set from roughly LO and up to around 68, the blower speed is blowing hard. My hair looks like Cindy Crawford in a Pepsi commercial ; )
However as I increase the temp above 68 the blower speed starts diminishing.
By the time I'm at 72 and over the blower speed feels like it's at roughly 25-30% of what the max was when the the temp setting was set to LO.
The rear again seems unaffected. If I set the temp to HI and blower to HI, it'll blow full blast. Only the front vents are affected.
It also appears to blow slightly harder when not on recirculate. The A/C filter is fine, and the fan under it is spins freely.
I believe this can't be a fuse as the blower works well when the temp settings are LO.
It's cold right now in Austin, and I need some heat. Any ideas?
