Cleaning the Engine Compartment
I cant imagine how long the previous owner drove around with the leak. It appears to be the power steering, but now sure if it is the pump, hose, or gearbox, but I cannot tell from the level of fluid and dirt that is caked onto the drivers side of the engine, wires, hoses, axle and knuckles.
What is the best way to clean the engine compartment to troubleshoot leaks (1996 LX450)? I don't have a car wash locally. I would like to minimalize the amount of mess it will make, as I will doing it in my attached garage.
I will post picks when I get home.
Thanks in advance!
I'm a fan of Purple Power, lots of towels and brushes. I've seen countless people pressure wash their engine bays and it turns out fine, I know my luck though :frown:
I used 2 quart sized spray bottles of Simple Green to clean up a dirty engine and front axle. It was on sale so I figured I would try it out. Parked it on driveway, presoaked it all with a fine mist of SG and let it set for an hour. Rinsed off gently with garden hose. Let it dry for 1/2 hour, then started spraying SG with hard stream from hand pump on bottles. Best to wear eye protection for this. Got up. Lose and really pumped hard on all the really thick heavy spots. Hosed it off again with just my finger over the garden hose. Really cleaned up nice. My PS knuckle had been leaking bad, and if was clean enough to work on bare handed. Also it cleaned up inside of wheels nicely. I went back to the store and bought more SG while it was on sale!
Just get it steamed...
I clean a lot of Land Cruisers that have be self lubricating for years. I soak with Simple Green and then pressure wash. Do this with the motor running and don't shoot things like the distributor. Have not had a problem yet. Works well.
@ewillis Where does one go to get an engine steam cleaned?
it isn't easy to find unless i am just searching for the wrong thing.
Most reputable detail shops offer it as an add on or stand-alone service.
My engine is ugly though so I would rather look at the dirt...
I have used a number of cleaners (Gunk, Simple Green, Purple power, etc....) But I wouldn't recommend using and rinsing them off in your attached garage! I don't like to use the GUNK stuff, but it sure works well - it can't be good for you or the environment! But maybe use it once (for the really bad stuff) and then move to a more friendly product like Simple Green or some of the citrus based cleaners.
I do recall that Simple green should not be left on Aluminum for any extended period of time....
Here's my engine bay as of last week. [1991 HDJ81]
It's not my goal to have a "detailed" engine bay - but boy is it more enjoyable to work on when its relatively clean and you can stick your arm in there and not ruin your clothes!
Thanks for the recommendations. Simple Green did the trick with a couple of large storage containers to catch the run off. I laid an old shower curtain underneath to catch what the tubs missed.
Now I am not sure it is the power steering pump leaking or the engine.
A hot pressure washer and castrol purple degreaser are going to work best. If you soak it first in the degreaser overnight it will help break up the nasty stuff. I have had good luck with the castrol degreaser even when using with a hose. The best really though is hot steam and a degreaser.
Crank seal and oil pump drip down front of oil pan. Power steering pump will usually leak out the back of the pump all over area including oil filter. Power steering hoses can leak/seep all over frame and have red drips at bottom of hoses. BTDT!
I am starting to think it is not the power steering. However the power steering has dead spots after driving for a while. It becomes manual.
Has to be the power steering. The frame rail and hose from the radiator back to the engine mount is coated, as well as the the engine has high as the oil filter.
