choke pull
Are you asking if the choke cable is permanently attached to the rod on the choke knob?
What problem / issue are you working through with the choke cable?
for those who follow me.. the choke pull, warm pull, and fresh pull are all molded to their rods.
already saw this one, thats where i got my idea and got started. he didnt mention the choke knob was perm molded to the rod. I do notice in the pics now that his choke knob is not refurbished.
Your choke knob is Solid Core cast Asbestos ( Vermiculite) onto a Mild Steel D groove shaft
If u attempt to remove it , it will shatter into several pieces with minor - moderate force applied
Your warm pull & fresh pull knobs are cast on the D groove shaft , But are removable with Moderate Force twist counter clock wise motion
Your choke cable must be restored as a 1 piece assy.
This is some of what can happen to your D groove shaft if u attempt removal of the knob itself
This is what can happen if you don't ...........
For whatever its worth, when i redid mine i soaked them in good old windex and a used a green abrasive dishwashing pad to scrub them a bit. I couldnt believe how much yellow/brown dirt/grease came off knobs that looked fairly clean.
I then used krylon spray paint and a teeny bristled paint brush to dab the paint into the engraved parts of the knobs (just sprayed a bit of paint into the spray bomb cap and dipped the brush).
Really simple and makes a huge difference. Good luck.
D
