I know how to fix that problem.
V8 and automatic.
V8 and automatic.
Lockers act squirrely if the tire pressure is off from tire to tire so make sure theya are within 1 PSI.
Will do--thanks.
I'm starting to think my idle issue is my brake booster.
It's not every time--but frequently, when I'm coming to a stop, it will die right as I hit the brakes.
Is there some way to isolate the booster & drive to confirm? Can I just plug the air line & try it that way?
I have really hijacked this thread......
Look at your carb, take it out make sure all the parts move and the butterflies are moving freely. I had the same problem with my 40 when I first got it, to make it home I had to keep my foot on the gas and brake at stops so it wouldn't die. I got a carb kit from Napa and broke it all down, one of my butterflies was shut and would not move so I assume that was the problem (since I rebuilt the carb I could not pinpoint the problem). Afterwords, the carb was like new, I only got the troll hole carb, because I wanted to get rid of the extra intake ports on the old carb. I know you have a new carb...but you never know, give it a look see.
