Check engine on and car barely accelerates
California
As I was leaving Safeway parking lot I noticed my check engine light is on at first I though it's gonna go off any given sec, but as I hit the main road the car wouldn't accelerate even tho I was pushing gas hard. After a minute or so the check engine went off and the car was fine I drove it good 200miles with no problem. I was wondering is this some electrical probables because recently I just changed the mass air flow sensor.
What kinda car and what code?
Fzj80 1994 4.5 I couldn't get a code for it because it didn't last long.
Ok, it's approximately 1515 PST. I'm going to attempt to drive a klick to the local beef market place for something to cook rare. God sparing I don't implode my HG, or the frame cracks in half, or the wheels sheer off killing the bus of nuns. And heaven forbid on the this 75* sunny day my A/C gives up.
Enjoy your labor day folks. Be safe out there. These 80 series can be death traps!
This didn't last long at all.
Masud,
The code should be stored, as retrofive said. You need to know the code first before you can tackle the problem. What's interesting is that it went away. Faulty connector somewhere probably, but you need to know where. Fuel pump relay (expensive little thing), MAF, or 1000 other things.
Dingo just did almost the same thing about a month ago. Did it 2-3 times. Turned out it was a loose connector that would disconnect when I least expected, turning Dingo into a sloth in full limp mode. I disconnected and reconnected all my connectors: Mass Air Flow, Throttle Position Sensor and Idle Air Control. I'm pretty convinced it was the MAF connector. All is good since then.
Masud,
I just did the diagnostics and the code is complicated can you help please. The check engine light flashes one and then twice and the four times and then three times (1243). I couldn't figure out unless I'm reading it wrong
I had the same issue Masud....OBDI scanner confirmed it to be knock sensor. Changed the first one (the one which is difficult to reach easily) and the car was back to normal...All the best with yours.
Yea that's what my scanner shows. Other than being hard to reach is there any other tricks to it and also where did you buy a new knock sensor and was it OEM?
