Thanks Landtoy Dude! I just pulled the modulator cap off and
lo and behold there was a tiny little spot of carbon on the filter.
No carbon in the bottom of the unit. Tip: don't drop that little filter
'cause it's a bitch to retrieve from down the side of the engine.
I removed the + cable from the battery and it cleared the CE light.
Tip: disarm the alarm system first 'cause it ain't gonna crank when you
hook the battery back up. It will however flash and blow the horn till
you get the fob and turn that sucker off. The alarm wasn't "on"
when I pulled the battery cable but it was enabled.
I've started the truck a couple of times and the CEL appears
no more.
Time will tell if that has done the trick.
The wife says you are a genius.
Ohm....cruiser,cruiser,cruiser.....Ohm
I remain in awe,
