Check Engine Light?
Basalt, Co
Running a code 133; O2 sensor slow to respond, bank 1, sensor 1.
My cat was just replaced, what am I chasing down?
My first thought is to replace the O2 sensors, but they are expensive and don't usually go bad. The truck is new to me, and I don't know when, or if, the sensors have ever been replaced. She's got 210,000 miles on her right now. Who has been down this road before?
First test the O2 sensor to make sure it is within specs.
Then depending on the results call CDan and order a set up and you will be good to go!
Look at the air intake tube. My LX was doing this and it was because the tube had cracked adn was letting air in no tfrom the intake. A role of Gorilla tape fixed it.
The other thing that sometimes happens isn't mechanical, it's electrical...sometimes the wire in charge of monitoring gets shorted or frayed. Double check as it's a lot cheaper than an O2 sensor
X 2 on what Trapper recommended. Had this same problem on my 94. Different code, but same issue. Turned out to be a wire that was shorting out. The wire harness from the O2 sensor needs a sheath around it.
Ok, so I checked everything out pretty thoroughly. the intake and egr system all look like they are in good shape on visual inspection. I checked the wires to the O2 sensors and everything looked ok, except one zip tie was broken and the wire loom was rubbing on the driveshaft. It hasn't worn through the ribbed wire loom protector yet, but surely would have been an issue in the future.
What I found that might be of concern. The PO replaced the Cat. where the sleeves are welded on, there are a few pin hole leaks. I don't think this would be a problem if there was only one, but I found at least three. Would this be enough to throw a code? These are very small leaks. I don't know what else it could be, anymore thoughts?
:cheers:
