check engine light
No trick at all. You just have to fix your truck, then pull the EFI fuse, or disconnect the battery.
The Check Engine Light (CEL) is an error condition. Your engine ECU is telling you something is wrong. It will stay on until you fix the problem that is causing it to turn on.
And if it's for a '91 Land Cruiser, you will have better luck if you post this in the 80-series section.
