Check engine light "P0116"
NexusD
SF Valley, Cali
Hello everyone,
This is my first post of the New Year so Happy New Year!
My 97 LX450 w/ 110K miles on it through a check engine light with a code of “P0116” something called the “CKT” temp coolant this morning. I have never seen this code before on this vehicle. This happened after start up in the early morning hours. The temp out side was cold; some were around high 30’s, low 40’s. I know that doesn’t mean much to you east coasters but here in So Cal that’s cold. Keep in mind I have know problems with the vehicle besides a few oil leaks. Everything has been pretty much ok until now. Any help would be greatly appreciated.
Thanks, Dan
It's saying that your coolant temp can't be what it's reading.
It's checking your ECT to see if it's working properly.
It's usually a bad temp sender or stuck open t-stat.
It comes on when the car has been running for 5 minutes or more and is not reading 50 degrees F or is less than 95 degrees after 20 minutes. It has to do this over the course of two trips.
If your ECT is reading cold you will experience bad mileage, bad performance, black smoke, smelly exhaust.
If the t-stat is stuck open you'll be getting poor heating too.
Thanks for the info! So should I replace the T-stat? T-Stat has about 25K miles on it. Were would the temp sender be located? In the pass week I have seen a drop off in gas mileage and smelly exhaust. have not seen the black smoke yet or the bad performace.
Thanks, Dan
Hold on, I wouldn't do anything.
I have had this code twice. According to the FSM is it detemined that the temp change between two points was out of limits.
It happened once in Dec 2005 and a second time in Jan 2007. I read other posts where others have had it with similar frequency.
Now, if it starts happening on a regular basis, I would troubleshoot it.
Good points Thanks Romer
In the 97 80's there is a tsb for an updated ECU for the code P0116, EG003-97.
The part number for the new ECU is: 89661-60652. You don't need to fix anything if you are ok with checking and clearing the code once in a while. It might become more persistant(sp?).
I wonder what that part will cost? Wonder if toyota will do a free upgrade? As long as AutoZone offers the scan tool for free to use. I'm ok with clearing codes. I just don't want to have something big happen when I'm out on a trip. Thats why I was concern with throughing this code.
A 10 year old vehicle will most likly not get any help from toyota warranty. Unless you have a long service history with a dealer, even asking is pointless. But you could try. This code will not cause a breakdown, just a light, this is why they (warranty not your dealer) won't help you.
Yeah I didn't think toyota would lend a hand with concerns with warranty. Like I said before as long as I'm not breaking down I'm cool with the light show.
Thanks again for the input. Dan
I had the same issue last winter. I replaced the TStat with OEM etc.. but I eventually "solved" the problem by buying an OBDII scan tool to reset the CEL. A new ECU is over $1000.
The funny thing is that I have not seen the CEL in about a year. I know I probably just jinxed myself.:doh:
Dave
