1989 Toyota pickup 22re 2.4 cyl 2wd. 5spd.
Check engine light code 21.
I know this code pertains to the O2 sensor before the cat. But to make long story short,..
My spark plug#1hole seems like it's cross threaded. It sits in there tight, but I feel and believe it needs and should go in just a bit deeper (as compared to the other three). The PO didn't tell me about this issue.
When idling, it idles okay,,,but once the engine warms up after a few miles of driving, then it seems like I have a hard time trying to accelerate (Unless if I floor it) then it's kinda okay.
I've been driving this way for about 10k miles now. I'm actually getting kinda use to it, but would like to see if I can fix the issue or not.
Others have recommended me to clean/replace the TPS, but it looks hard to get to.
question#1. Would/can a spark plug not seated properly all the way in cause a code 21?
question#2. Would anyone recommend chasing the threads with a tap&Die kit, if all else fails, use "heli-core"? (spelling???)
Question#3 Replace the O2 sensor and don't worry about spark plug#1 because that isn't relevant?
I looked into the O2 sensor, and it'll run me about $114 from CDan. As mentioned, I'd have to get a california emmissions O2.
Give my your 2cents worth.
Thanks.
-Pheng
Thanks.
-Pheng
