Looking to have better articulation, not planning on heavy weighted truck. Softness in springs and some added travel would be great, but budget challenged at this moment. With expense of lockers new ring an pinion, bumper winch, sliders etc etc , and etc .. By the time im finished it will be a 30k truck.
If you’re on a tight budget put the money into preventative maintenance rather than increasing articulation. A stock truck with 285’s has plenty of travel to have a blast.
Yep. That's my truck, and the pin hasn't been installed for many years now, once I realized the damage it was doing. I just run 3 axle bolts now, all the time. Also ground the sides of the bushing cups to allow more twisting in the brackets. Not that I'm recommending this- you'll probably kill a busload of nuns.
Ive done crazy serious trails in my 80 on a big lift and many times Ive done it with stock lift 80s and they can basically do all same trails. front sway dissconnect is a winner.
Actually, I don't believe disconnecting the front sway bar will net any articulation gains all by itself. The binding that is inherent in the stock radius arm setup is the limiting factor. Once you alleviate that a bit, the sway bar comes into play.
Probably I explained it wrong, if I continue to trick out my truck I would be investing close to 30k CDN of course. Cost of LC , repairs, bumper, winch, lockers, ring an pinion, suspension caster kit drop arm panhard etc , new brakes liquids, knuckle rebuild, etc etc
