Wow!
Lots of new info here!.
I finally have my 4wdbits intercooler for the 1HD-T (and my 3" exhaust also, but that's another history).
I was definetly going to get the Cross Country 4x4 one, but I got tired of waiting for them and a friend got a very good deal to bring some 4wdbits ones, so I got the 4wdbits.
My main concern is the elbow and the rear position of the 1HD-T version. I'm veeery interested on the discusion going on here about the right location for the scoop. (I know I can not choose the location, but if the scoop won't be a good improvement in this intercooler's particular case, I might try some other alternatives).
In the spanish forums there are several opinions about how to do with this intercooler:
1) Just install it and leave without scoop. Warren says there is an improvement just by installing it, I wonder how much. Mudstorm, have you measured the EGT drop with intercooler but without scoop?
2) Install it, make no scoop, but raise the rear of the bonnet and remove the rubber gasket in the rear. There is a guy in the forum that bought one of these and is also a mechanic I trust that is convinced that this would improve under bonnet airflow greatly and would be as effective as a scoop. I can't see it being so effective, but as I said, this is a very knowledge guy. He also told me that this would be effective even at low speeds thanks to the engine fan that would move enough air to cool the intercooler as well.
3) Install intercooler with no scoop but with a fan, to force underbonnet airflow to circulate through the fins of the intercooler.
4) Install intercooler and scoop.
5) Install intercooler, scoop and fan.
6) Make an underbonnet air circuit to drive the ram air from the front to the intercooler, just like the Toyota Land Cruiser 120's or the Peugeot I post pictures of previously in this thread. This would be a complicated option, but might be very effective.
What do you guys think of these options? Any that you think is a particulary good idea?
Tapage, when you said you like it and it's your way to go, do you mean the 4wdbits one or the cross country one?
Install the intercooler with a scoop, install a fan later on if you need it.
This is what the manufacturers do and they've spent a lot of time testing to show it works. Not with wool on the bonnet either.
Propping up the back of the bonnet is a really bad thing to do. It will pull engine fumes into your cabin intakes but do little for cooling airflow.
Even if you do get air moving in the right direction, you'd be pulling hot air off the engine and radiator through your intercooler. This is not smart.
. Sure if they had to do a new scoop for the 80, they would do it quite different.
. A pipe, a hole, and...the compressor
. I will work on it soon, i have no ccalculation capacity for it, so i will do by experiement.
. But maybe it is just a patrol thing
