Cheap O2s?
Traverse City, MI
Website
www.myspace.com
I dont know anything about those, but I there is a cheaper alternative. Try cleaing the O2 first before you replace them, it worked for me.
Since the carbon built up on the O2 sensor is not soluble the only way to really remove it is by heating it up and then placing it in water to super cool it. Take the O2 sensor and heat it up with a torch until it almost turns red, you dont want the whole thing glowing red. Then dunk the sensor in water. The black carbon should come off the sensor. I had to repeat this a process a few times before black particles quit appearing in the water. Then put the sensor back and start up the car, dont be surprised if the car smokes a little at first it will go away.
Don't waste your money. Seriously, bad factory O2s are better than these cheap POS sensors. I have some of these POS sensors if you want them.
Cheap O2 sensors may lead to more problems. I prefer to pay the extra for Toyota and know its fixed right. They can be a PITA to do yourself, after a miserable experience attempting one on another vehicle I now happily take it to a shop...
Other than mileage is there anyway to find out if the O2 sensors (2 right) need repalcing? Read that this can have a 5%+- effect on mileage, can anyone verify?
thanks
oxyensensors.com sells the Denso OE sensors for about 85.oo$ each (avg. if I recall) when I purchased mine a while back.
Sensor = $142
I just had a quote from Toyota for the left sensor. $295.00. Is there a less expensive alernative. My check engine light stays on. Mechanic says it's the left o2.
We are working on a?
