Chassis ground wire question
Beaumont, Texas
Website
www.marklowimagery.com
I am installing new lugs on my battery cables and have a question about the smaller ground wire that comes off of the negative cable to chassis ground. It is probably 8 ga and about 6 or 8" long. Since I have the 200 amp alt. installed and am running an aux battery in the back, should this wire be larger, say as large as the negative battery cable? I am sure Toyota decided to go with this smaller ga wire to chassis since they could have easily used the same size as the main cable. The only reason I can think of is maybe it is to control the maximum current carrying capacity through the chassis. Also, since it is only 6-8 inches long, the resistance of the 8 ga wire at this length would be equaled to a much longer 1/0 wire. Anyway, I want to know if I should replace that wire with 1/0 matching the battery cable size and how would this actually help? I did find a post that had a similar question but no direct answers.
Mark
Alot of car audio guys pimp the idea of upgrading the grounding straps to the chassis and engine block. It may or may not actually help anything, ymmv, but it can't hurt anything.
If you've got spare 4ga lying around, you might want to do it. IMHO 1/0 is overkill for 6-8".
The negative cable should go directly to chassis ground. Are you saying the cable connected to your negative post on your battery is 8 gauge? Your battery to chassis ground connection is in the bigger cable.
There is more than 1 ground wire from the - terminal on the battery. There is a thick one that goes to the frame. Thre is also a 6ga one that toes to the body inside the battery box.
Where did you find a 200 amp alternator?
It is a Mean Green and I got it from Man-A-Fre. It probably only 80-85% of its raiting but it does the job for me. I run several radios and a 1KW RF amplifier and some other things and it is able to keep my alternate battery fully charged without sacrificing current for the normal vehicle loads.
Image;
I must see that 1kw amp!
IMO that ground wire (~10ga) is the primary body ground for the front lights, etc. It is a weak point in that it will corrode under the bolt fastener and many people will not find same. I would replace with #6 gauge and check other grounds as well. I've written other posts on this in the past.
See link for my crap.
http://homepage.mac.com/dfmorse/RigProj/index.html
Ok, I understand what you mean. I applied anti-corrosive compound to that connection after finding it looked like a very poor connection to the body. I just have a 6" 1/0 jumper already made up from an old multi cell battery bank from a cell site. I was just going to install it in place of the stock wire just because it would fit so well. For now, I have just added a lug to the end of the stock wire and attatched it to the battery with the main neg lead. I guess I never really thought about it but did not realize that the 1/0 neg lead goes directly to the frame. It makes sense but I guess I never actually followed it to find out. Do the head lights actually ground inside the battery box beside the other small ground wire?
I will get some pictures of what I have done and also of the 1KW RF amp. It covers 3.500 - 29.000 Mhz and is designed tfor maximum output around 7.000 Mhz. With 75 watts drive, it makes 1000 watts +/- depending on how well the antenna is match tuned.
Does it go to the frame or the block? (I'm not 100% sure without looking.)
The wire he is referring to is a body ground. The chassis/frame ground goes to the engine block and is the heavier gauge wire.
-B-
You can't add enough grounds IMO. Normally when installing big alts, I run a section of 2guage (welding wire is great for this) from the Neg post on the battery to the alt 'area', either the alt bracket or a convenient ground close by.
An additional one to the engine doesn't hurt either. On my 4R turbo, I added these 2, 1 to the alt bracket and 1 to the engine block under the distributor. It really helped with the idle.
There is no downside to this mod at all. And a lot of universal ground straps (ford uses varying lenghts of of the double looped strap type) are available at your local auto parts store.
ST
The whole +/- pole designation can be a bit missleading. The electron flow actually goes from the - pole to the + pole. Electricity (electron flow) behaves a lot like water. It goes through the path of least resistance. If you put a big device in with a big bad + cable but a shoddy ground, you'll get shoddy results.
The ground wire to the body is small because that is all that is needed for the stock loads, the biggest load is the starter and it grounds to the block that is where the main negative wire goes, when I did my dual battery setup I replaced the small wire with a 6ga, not sure the tiny bolt and thin sheet metal it attaches to would carry much more than that anyway, you could run a 1ga wire to there if you wanted to will not hurt anything, just overkill. overkill ground are never a bad thing.
If you wanted to improve the ground system though a better choice instead of running a single 1 ga wire to the body from the neg terminal might be to replace the bonding straps from the block to the body and frame, you already have a high current ground to the block from the battery, your "upgraded" alternator is dumping its current to the block also , so make the engine the central point for your ground system, make several larger (6 ga or so?) ground paths to replace the stock ones, there are some on the drives side of the engine, one near the back of the motor to the firewall, and one from the body to the transfer case under the truck, there are probably more that I have not seen.
yep, my avionics instructor used to make us trace circuits from ground to positive folowing electron flow,
now that I am no longer in school I trace circuits from positive to negative, it is just easier as that is the way most DC circuits are layed out,
it is also easier to work with diodes from positive to negative, just folow the arrows.
Oh yea, now I'm jealous; very nice rig!
...l
Thank you. It is always a work in progress. Since I had to remove all body ground straps ect for the overall paint job, I am now replacing them one by one as I decide how I want to do them better this time. I have the tail gate, hatch, and the hood done and the body at the rear quarter by the hf antenna is bonded to the frame with 3" flat copper straps. Now all I have to do are the doors and I think I want to do it differently than before although it worked fine then. I just went from the door hinge bolt to inside the pillar behind the trim pannel for the rears and between the door hinge bolt and the front fender top fastner bolt for the fronts. I of course used the anti-oxident compound for all connections. They say that it is best not to use existing bolt holes but rather remove paint and use self tap stainless screws to bond body pannels. I just hesitate to grind away paint since I just finished repainting but probably will do it anyway. As long as I keep it neat and clean and corrosion free, it should be fine. I normally have no problem with stray rf until I run the amp but right now that has not really been a problem. I have my noise level down to nothing with the engine running so that is fine.
Lets hook up on the radio sometime mobile to mobile. We could probably use 17m when it is open. I am in Beaumont, Texas to give you an idea of distance between us. my call sign is N5LPT and I am on QRZ.com. Tell me your call and we will give it a try sometime
Mark
I'm one of those that think that you cannot have too much good grounding (within reason) I remember once talking to Dan and him telling me that the electrolysis within his cooling system was enough to have his circuit tester give slight glow when touching the hoses throughout the system!!! :eek: I tried the test and got no glow. I have several additional good grounds off of the head and the neck coming off of the head that are added above whatever stock grounds are allowed on the assembly line. I realize that this is not a scientificly validated statement and is anecdotal but, again, I think that adding few additional good ground straps here and there is good insurance. JMHO. :cheers:
Ive replaced ground wires on previous cars and have gotten great results. And yes, it doesnt hurt to use a large gauge wire but what you dont want to do is just put all kinds of grounds just anywhere. Doing so can create ground loops which are unwanted. Also, most people dont know not to use the seat belt bolts. They are hardened steel and dont conduct well.
