Here's the rundown.
1991 FJ80 199k has been sitting for years when I purchased it a year ago. It had an "aftermarket" alarm system and had the starter rigged on a push button. Fast forward to what I've done to the truck since DOP...
-Removed aftermarket alarm and repaired splices with solder/heat shrink
-Removed push button and all wiring
-Unlocked Factory Radio
-Replaced Starter
-Replaced Alternator
-Replaced battery
-Replaced starter solenoid/starter activation pigtail
*I've replaced way more items but these are the only electrical items that would have anything to do with my issue I believe*
When everything was removed the truck started fine with the ignition switch. A few months later I attempted to start the truck and nothing. A small peck with a hammer on the starter solenoid and it would fire up. This lead me to believe the starter was bad. I replaced the unit with a New Bosch unit and it started normally for about a week. Then came the same issue. A small peck from a metallic object and it'll start. I inspected the wiring to the starter (large wire) and all is well. I did notice the starter pigtail was slightly deformed so I replaced it with a quality terminal.
I measure the voltage with a volt meter and with key in "start" position its getting 11.8v. The battery has 12.xx volts. The starter will not "click" or make any sound unless "pecked" with something.
I made a 4 foot jumper wire with a terminal on one end and bare on the other. I attached one end to the starter solenoid and then touched the other to the positive terminal on the battery and bam....it starts every time.
I'm thinking the wire from the key switch to the starter could be the issue causing a voltage/amperage drop when attached to the starter and loaded.
Does anyone have any experience with this issue? Relevant wiring diagrams? Thoughts/Opinions are welcome as I'm almost to the end of my rope...
-Replaced Starter
-Replaced battery
